Except that Acetone eats some of the resins used in carbon fiber. There are other solvents on the market that will do it though without touching the carbon.wrcsti wrote:Acetone is just the right chemical.ringo wrote:Isn't it possible the foam can be dissolved out with a solvent leaving the carbon skin?marcush. wrote:speaking about wing section construction...
I cannot resist to point out that FI indeed does not have foam core wings as is evident from these pics.personally I always believed this was the case ,but I was made to believe it was not ...
