The way Mercedes extended the wheelbase makes it quite hard to even make special parts to make it fit to Monaco.
If you look at how close the driver's side of the front wishbones are to the rims:
The wheelbase was lengthened so as to bring the centre of polar inertia FORWARD. The car needed more weight to the front, so as to sharpen response of the front wheels. The SWB set up moved weight to the rear, providing better weight transfer to the rear wheels, and thus, better tractionwesley123 wrote:And like also stated it doesnt matter at all. If the car has twice as long wheelbase with the B spec okay, then it would make a difference, but it isnt, it is just a general misconception as they can simply increase the turning circle to overcome this drawback.gilgen wrote:wesley123 wrote:and also it is kind of opposite of what you want at monaco, you want lot of weight on the back, guess what the LWB car did? The reason it wasnt run was simply because of the lack of parts.
Mercedes had plenty of parts, but they elected to alter their car back to SWB, as it made turning on the sharp corners, easier. This was stated about six days ago.
In monaco you want balance to the rear to increase rear wheel traction, guess what it is what the LWB car does? Thats right, move the CofG backwards, then going back to the SWB car is simply stupid and completely opposite. The lack of rear balance cannot be overcome like the turning circle, so the onnly reason that makes sense to go back to the SWB car is because of part shortage.
Yep, the wheels are bought forward. But lets take it simple, you have 4 lines, placed like wheels. Then yo have a dot in the center of these 4 lines. If you move the right 2 lines further to the right, guess what happens with this Dot, it is effictively placed more to the left lines. So it is same with the ballast placement.gilgen wrote:The wheelbase was lengthened so as to bring the centre of polar inertia FORWARD. The car needed more weight to the front, so as to sharpen response of the front wheels. The SWB set up moved weight to the rear, providing better weight transfer to the rear wheels, and thus, better tractionwesley123 wrote:And like also stated it doesnt matter at all. If the car has twice as long wheelbase with the B spec okay, then it would make a difference, but it isnt, it is just a general misconception as they can simply increase the turning circle to overcome this drawback.gilgen wrote: Mercedes had plenty of parts, but they elected to alter their car back to SWB, as it made turning on the sharp corners, easier. This was stated about six days ago.
Schumacher certainly needs to find far more that 0.3 secs. But don't forget, Red Bull and Ferrari will also have their wing-stalling devices, which may give them an even greater advantage.JohnsonsEvilTwin wrote:I wonder how Mercedes F-duct will look like when it appears in Turkey.
Will they have a shark style fin as McLaren, Red Bull, Ferrari etc to channel the air flow to the rear wing? Or will it be round the sides?
Schumi reckons its worth 0.3 seconds...cant be bad!
logic tells us they would not have much ballast to play with.WhiteBlue wrote:Unless my memory of the analysis after Australia is wrong they said at the time that the W01 needed more ballast through lighter parts. The LWB wishbones were only a short term fix for this. Lighter parts were due for Turkey together with the active blown wing. Hopefully it will give Merc a much needed shot in the arm. Unfortunately it is now much too late for Michael to get into the WDC race but he may get on the podium or even win a race this year. That would be nice for a change.
