Pup wrote:WhiteBlue wrote:Why don't we use the facts that were provided by the team here. I don't think that Horner would obviously lie in such a situation to the press. He said that both men started on exactly the same fuel load and that on lap 40 Vettel had 1 kg more fuel on board due to often running in the slip stream while Webber was leading the race.
1kg is worth about a third of a lap at Istanbul. Hardly enough to justify having your drivers on different strategies, imo.
The drivers were not on different strategies, Pup. There were on exactly the same strategy. Webber reached the switch point to fuel saving one or two laps earlier because he ran in free air at the front while Vettel was slip streaming most of the race. Please read
DC's comment which said the same.
In the meantime there are additional
comments in the German language from Helmut Marko. I will give a translation further down. But first some other interesting details.
According to the article neither Marko nor Horner had a direct line to the drivers like Jean Todt used to have at Ferrari. This is why a team order or a request for team tactics had to be made through the race engineer (in Webber's case Pilbeam). RBR have now decided to install such a line for future use.
According to Marko team tactics were actually in place at RBR on Sunday in Turkey. Pilbeam was tasked to tell Webber that he was not supposed to fight the faster Vettel but conserve his car. It means implicitly that Vettel was actually told he would get preference. And here is what Marko said:
Helmut Marko wrote:Der Renningenieur hat den Auftrag bekommen, ihm zu erklären, was los ist. Also dass Vettel nicht ihn attackiert, sondern dieses Tempo gehen muss, damit er nicht von Hamilton überholt wird.
Webber sollte sich nicht gegen den schnelleren Vettel wehren, sondern sein Auto schonen, um dann die Attacken von Hamilton abwehren zu können. Warum (Webber nicht informiert wurde), ist bis heute nicht ganz klar. Dieser Ingenieur hatte einfach einen Blackout, er hat nicht richtig reagiert.
The race engineer (Pilbeam) received the order to explain to him (Webber) what was going on. To explain that Vettel was not attacking him but needed to go faster to avoid being passed by Hamilton.
Webber was supposed not to fight the faster Vettel but save his car to fight Hamilton. It is still not entirely clear today why (Webber wasn't informed). This engineer simply had a black out, he did not do the right thing.
The way I see this Marko and Horner had agreed to issue team order although they cannot publicly say they did. It is obvious that a short time fuel advantage for Vettel was supposed to be used as the excuse for Webber to let him pass. Of course this isn't a qualified reason in most people's view as the fuel advantage would have lasted only one or two laps.
Pilbeam obviously developed a hearing handicap
which was unfortunate for Sebastian as his team mate wasn't told to let him pass. It explains why Vettel thought he could push for the racing line on lap 40. It would have been a good way to mask that team order had been given.
