I think you mean just the opposite....They can't make heat on low load.That was the real reason that Mercedes could not qualify well but went much better with race fuel on board. They cannot get the tyres to dissipate heat on low fuel.
I guess we are talking about the same thing here. Dissipating energy means heating the tyres by internal friction. That friction - besides other factors - needs traction of the tyre on the track surface and a higher load by more fuel will help with both the traction and the dissipation. During qualifying they do not cary high fuel loads and run only short runs. Both isn't helpfull for heating the tyres. Typically Merc also had less problems with the option tyre than the prime. The option is softer and will dissipate less energy all other factors being equal.strad wrote:W/B said:I think you mean just the opposite....They can't make heat on low load.That was the real reason that Mercedes could not qualify well but went much better with race fuel on board. They cannot get the tyres to dissipate heat on low fuel.
WhiteBlue wrote:I have my doubts about that. That Q3 kissing of the wall was rather shy. He traded a bit of rubber but did not even scratch the wheel rim. I can imagine that the RBR boxes are a bit marginal due to the exhaust routing they do this year.ISLAMATRON wrote:I thought it was clearly said that Webbo's wall scrape in Q3 was what necessatated the gearbox change, or did I hear that in a dream?WhiteBlue wrote:Webber backs gearbox change over conspiracy theories
-IMG-Chaparral wrote:Sorry how do you know he didnt bang the rim
strad wrote:Looks scuffed at 7 oclock,,9 oclock and from 12 to 1 oclock quite frankly,,that rim must be thrown away
love that humorISLAMATRON wrote:that is alot of wall dust, yeah that rim caught a bad one
banged up as Chaparral said and probably took the gearbox with itstrad wrote:Ferrari for sure and I figure most the others...after any use, it must be sent back to the factory for testing for cracks. Paper thin man,,,paper thin
I have no idea what your talking about Autoautogyro wrote:You definitely could not build a proper mans racing car like a super stock like that.
Only thing with fence is they messes with AF sometimes....You can PP the color and the obviousness of fence in a shot but if AF does odd thing they you just get a bad shot....richard_leeds wrote:That's impressive panning, you've got the car so nice and crisp.
Personally, I like the fence - it gives a real sense of being trackside. Also the panning has blurred it so it is not too intrusive.
Dissaipate means to get rid of the heat..I guess we are talking about the same thing here. Dissipating energy means heating the tyres by internal friction
1. To drive away; disperse.
2. To attenuate to or almost to the point of disappearing: The wind finally dissipated the smoke. See Synonyms at scatter.
3.
a. To spend or expend intemperately or wastefully; squander.
b. To use up, especially recklessly; exhaust: dissipated their energy. See Synonyms at waste.
4. To cause to lose (energy, such as heat) irreversibly.
v.intr.
1. To vanish by dispersion: The dark clouds finally dissipated.
2. To indulge in the intemperate pursuit of pleasure.
dissi·pater, dissi·pator n.
dissi·pative adj.
dissipate [ˈdɪsɪˌpeɪt]
vb
1. to exhaust or be exhausted by dispersion
2. (tr) to scatter or break up
3. (intr) to indulge in the pursuit of pleasure
[from Latin dissipāre to disperse, from dis-1 + supāre to throw]
dissipater , dissipator n
dissipative adj
First of all, Strad is right about the true meaning of dissipation, but I will explain why I typically use it that way.n smikle wrote:Is generate you mean WB.
