The purpose of Air-intake/Scoop?
archebald23
archebald23
Re: The purpose of Air-intake/Scoop?
Shrek wrote:I meant reduce the inlet of the air intake of the engine or maybe the radiator inlets
what does reducing the inlet specifically do? will there be any significant changes/imporvement?
vonk
riff_raff wrote:F1 fuel systems are not fully closed-loop designs (ie. they don't have mass airflow sensors).
Terry,
Just happened across this post. I understand the FIA ECU (2008 spec) has a UEGO oxygen sensor input for each exhaust bank. If so, wouldn’t that close the fuel mixture control loop?
Cheers,
Harald
Techno-Babble = Meaningless use of technical terminology to feign knowledge.
