autogyro wrote:Here is a guess that gets away from the direct blowing of exhaust gas over the diffuser.
On full throttle, the mass 'exhaust gas' flow increases from the engine due to burning fuel. This flow alters the direction of airflow into the rear 'coke bottle' area. The main airflow is directed outside of the diffuser and upwards.
The result is slightly reduced diffuser DF and reduced drag.
Under braking the 'exhaust gas' flow reduces in volume with less fuel burnt and the airlow redirects inboard over the diffuser and lower wing section increasing DF into corners.
On high speed 'throttle on corners' the flow is of much higher mass airflow and the result is a neutral DF effect.
My apology but I don't get how the first statement matches the last. It would have to, for the car to stick in turn 8 at Turkey.
And the seoond statement doesn't make physical sense. As it's heat, not burnt fuel that the effect is being generated from. The vortex generation from the sides of the diffuser, at full throttle, creates a sealing effect, enhancing flow over the center section. The sealing would be less at off throttle, spreading out the air flow, making it less effective.
At Turkey,RB's performance compared (fastest in section 2) to Mclaren's non-blown performance (fastest in section 1 and 3) in the lower speed corners, would seem to contradict your theory..or I'm not understanding your theory.,
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
