Mclaren Mercedes MP4-25
imightbewrong
imightbewrong
Re: Mclaren Mercedes MP4/25
Herr_Koos
Great pics! First real look at the new package.
Interesting that the asymmetrical rear is still present where the old exhaust outlets used to be. The left opening now has gills over it while the right one seems to be blocked off completely. Can't see much about where the new openings are though..
autogyro
autogyro
53
Is it legal to swap the exhaust outlet from high to low depending on whether the throttle is off or on?
Paul
No, no exhaust geometry changes allowed.
autogyro
autogyro
53
yes but it is the same as the f-duct if a fluid switch is used.
gibells
gibells
So high to port and low to starboard?
timbo
timbo
111
autogyro wrote:yes but it is the same as the f-duct if a fluid switch is used.
Somebody quoted the rule, that you are only allowed single exhaust per bank.
Sawtooth-spike
loving the back end of that car.
How are they able to get away with the gills where the old exhaust used to be?
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
It is simple, these holes are there if the exhaust causes problems to simply switch to new ones, IF they rn it in the race this will be fully covered(or it has to do something with side view allowing these gills)
Sawtooth-spike
but they are only on one side.
I think they are part of the design. With the way Mclaren run there cool, its is likely they need that hole.
Herr_Koos
Sawtooth-spike wrote:but they are only on one side.
I'm also inclined to think that it's being used as a cooling outlet.
Hangaku
Parts of the rear diffuser look like they are painted light grey. Is this so the engineers are able to visually monitor the heat being applied to it perhaps?
Yer.
Herr_Koos
Hangaku wrote:Parts of the rear diffuser look like they are painted light grey. Is this so the engineers are able to visually monitor the heat being applied to it perhaps?
Pretty good guess. If anyone knows how to use paint for analysis, it's McLaren. :D
imightbewrong
imightbewrong
jason.parker.86
jason.parker.86
