Williams FW32 Cosworth
Re: Williams Cosworth FW32
wow check that beam wing :O
Great shots once again zgred!
raymondu999
is that an f-duct fin? It looks awfully small/thin if it is
失败者找理由,成功者找方法
roost89
roost89
raymondu999 wrote:is that an f-duct fin? It looks awfully small/thin if it is
It's your average shark-fin connecting to the rear-wing. :)
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
aral
aral
26
Yes, it is. It has a slight triangular profile, with the bottom being wider that the top, which is ery thin. The slot in the rear wing can be seen in the second photo.
wesley123 wrote:wow check that beam wing :O
Yeah the beam wing has a slot on the backside like the main beam of the rear wing.
timbo
timbo
111
I find this interesting: http://www.autosport.com/news/report.php/id/85425
Maybe because they don't have somebody of Adrian's or Ross' caliber at the helm of their technical staff, they need very experienced driver to give technical feedback and show positive direction. Probably Nico doesn't have much experience for this role.
imightbewrong
imightbewrong
Courtesy of nextgen-auto.com
mx_tifoso
mx_tifoso
volarchico
volarchico
From that shot it looks like the exhaust runs all the way down and back behind the diffuser completely. Must be an optical illusion.
roost89
roost89
volarchico wrote:From that shot it looks like the exhaust runs all the way down and back behind the diffuser completely. Must be an optical illusion.
I suspect it's hooked up to some sort of venting system, where the exhaust gases are fired straight out of the building =)
timbo
timbo
111
Most likely!
Otherwise the exits are below the ground.
Anyway, Williams car improved quite a bit. Nice to see them fighting in top-10 again!
zgred
kalinka
kalinka
WOW ! That's a masterpiece of a pitot-tube array. They must have a new front wing and/or new splitter if they are so keen to get some flow data on that area.
raceman
^^It seems to be a new floor with some different front shape underneath the sidepods..... :roll:
Francesc
Francesc
50
