I think rolling a car around on setup wheels is quite a weird idea ..i would use my measuring tools only for measuring...but then ...what do I know.RacingManiac wrote:I think I've seen triangular ones used on some GT cars at a ALMS race. We've used a steel square plate for our FSAE car. I suppose the round one allows you to roll it onto a scale...Though with their pneumatic jacks and stuff I don't see why they care....marcush. wrote:setup wheels is making the job a lot easier...and removes hassle till suspension taking a set ,preloads from stering inputs,finding true track width etc.. it pays to have a set of those for every racecar.
Is it necessary to have them round ? for ease of measuring ,and avoiding cars to roll off the pads accidentially ..(with all those people around ..you can´t believe what does happen..)
Those little pipes under the main pipe may have sensors in them. They may be measuring back pressure.Pup wrote:
No holes drilled in the bodywork of this one. Looks like they're using an exhaust tip that bolts to the floor. I suppose they might swap that out with different shapes, perhaps testing an angled cut like Ferrari moved to?
Pup wrote:
Looks like this is designed to accept another piece. Some aero bits to influence the shape of the exhaust plume perhaps?
My guess is that they are just screwed to the floor to reduce vibrations. That, and it provides an easy way to alter the exit shape if they plan to experiment. It's probably a different material because it's machined.ringo wrote:Those little pipes under the main pipe may have sensors in them.
Good catch! imightbewrong asked about that "grating" earlier, but I think you're right and it's another pitot rake.feynman wrote:I would suggest that the "cable" from the data-collection box is in fact armored, heat resistant, air-lines leading to an array of pitot tubes, at least that's what I think I can see lurking in the shadows of this image:
[IMAGE 2 POSTS ABOVE]
More mapping of airflow for the big McLaren computer.
They have never had asymmetrical exhausts....just exhaust openings that were the main cooling outlets. Exhausts and cooling is now separate so exhausts will never be asymmetrical, the cooling outlets might be however.raymondu999 wrote: Given their love of assymetrical exhausts though, are they showing any signs of using an assymetrical exhaust setup for the floor?
