Aha, that worm-like thing is what does the 6 degree adjustment, hence the lever-like shape, but it does so much more.
Ingenious.
747heavy wrote:Well some people argue, that they just see this "wing flutter" or "buffeting" of the RBR front wing when in runs in the down wash flow / vortiece of the Ferrari in front.n smikle wrote: It still passes the F1A tests. But if it was really intended for the wing to bend I think with this the wing will vibrate like a spring anytime you have turbulence especially with the large percieved displacement. Almost like a plane wing fluttering.
Webber travels in a straight line.
It is also noteworthy, that the RB& is appartenly struggleing a lot when running in traffic, behind another car. See Vettel in Hungary, really struggeling to overtake.
So I do think, that the front wing of the RB6 is affected by running not in "clean air", and when in front, they just make max. use of it and disapear into the distance.
Even in Touring cars (DTM) running in traffic affecting the cars quite a lot.
Ahhhh finaly...ah and btw ..simply calculation will reveal that a rigid front wing centre would need a rake of 2.7° ( plank leading edge rubbing the ground and rear ride height at axle 80mm to get to something like 69mm of front wing height...,using the plank leading edge as the pivoting point)
The most important thing to me is, as for 747heavy, to notice how each wingtip moves as the ferrari in front slides in...To me it's the proof that the wing is overflexing, but we all agree on this. The matter is: if an evaluation can be made about the downforce loss when the wing enters the wake, we can maybe have some interesting thoughts about the expectable behaviour in the next stiffness test.(or at least figure out if the whole thing deflects in a linear fashion:not, to me).tok-tokkie wrote:That picture of the Red Bull wing 'flexing' seems to be it wobbling.
good question...raymondu999 wrote:We've seen this year that the movable front wings (I mean the actual, 6 degree allowed movement, which most teams are using to trim the car's handling, introduced in 2009) can fail and be stuck. What happens if this happens to the movable rear wings? And I wonder, actually. Will the teams gear the ratios for top speed in conjunction with the "non-flexed" configuration? Or will they sacrifice some engine power in "normal" situations, and only use their top speed when their wing is moved?
Yes Ringo you did !!!ringo wrote:I commented on this 20 page back or so.
my concept was slightly different, but now that i think about it, the actuator could be used to weaken the wing somehow.
xpensive wrote:Intersting measurement that, 760.643 mm, but with a +/- 2 mm tolerance...anyone of my designers putting that on a drawing would be fired on the spot!
