One M/G with a diff is 'probably' going to be heavier than two MGs.
The main problem though is that one MG would loose more energy in the gearing.
There would be far more moving parts and a wider and more complex mounting and packaging requirement as well.
Of course if allowed there would also be finer control over torque bias with two MGs.
With the expected objections to policing TC etc on the rear axle, I am sure one MG or multi segment MG would be the choice.
Three will be the number of MGs mounted IMO.
There is no benefit in full 4WD over mainly rear wheel drive in F1 because of the traction requirements. However handling can receive a significant benefit from torque control of the front wheels. The tyre guys on here might have some interesting comments, if they can apply their technology instead of guessing that is.
