forty-two wrote:Wow, lots of info there! Thanks for the concise reply ESP.
I didn't hear you get another name check in the FP sessions today though! Should I listen out for one tomorrow? :D
Answer, no; reason, ill be at work sadly.
Sauber are now blowing the main element, new to me ill say, as they were blowing the lower element early on this season. They must have used Albert3 to convert to the main plane.
One other thing to add is that ther eis one more blown wing and thats the Mercedes passive idea, that one blows the wing when the air speed reaches a certain level and then blows the wing on its own. It works, but is more flawed than the McLaren or Renault solutions. It dosnt let the air attach quick enough like the Renault idea but also is harder to blow like the McLaren idea. It dosnt cost as much as the Renault idea either. If it was on last years Brawn, it would have been a massive plus as the DDD would have had enough downforce at high speeds, but now it is a solution that was dated once it was concived. Mercedes should just go and do a Renault type solution.
