Movable skirts IMO would not have any chance. The ground effect implementation that they would go for needs to be safer and more practical than the early solutions. I believe there are several elements to the thinking of relying more on ground effect than they do now. Have a look at a classical ground effect car.timbo wrote:Ground effect (with skirts) gives more downforce for a same drag than current wings/undertray combo. It creates less wake. If the regulations are made in such way so teams would not rely on complex vortex structure to create downforce it should also be less sensitive to wake.
The Lotus 79 Mk IV shows how the side pots start early behind the front wheels.
This is how the side pots would work as venturi tunnels creating wing profiles underneath. A very slim I-4 engine would naturally help with this design. Turbos with exhaust and inlet piping, inter cooling, AWKERS and HERS will need a lot of additional space which would be helped by the huge side pots.
The front wing could be a very small standardized element or go completely as in the Parmalat BMW Brabham. The front downforce could come from the floor.
