He raced without F-duct Marcus.marcush. wrote:did I miss something there Hamilton did drive without F-duct in monza ,did he? (even thohgh his race did not last very long ).
Button was racing with a different front wing at Spa, what was the difference between Spa version and Monza version?raymondu999 wrote:What I don't get is why didn't McLaren reduce Jenson's downforce level slightly and get a 340k top speed as most others were.
But if you slide much less because of the high DF, and you consider Jenson's smooth style , and hard tyres, it's maybe just not enough to heat them up.. Monza actually has a fewest corners to make your theory work. Maybe it's true on a more conventional track, but not in Monza, where you have more independent effects working against it...? Actually I think you're right, but maybe it's a different story in Monza...?raymondu999 wrote:I thought DF generally helped to heat the tyres to their working temps, but not wear them down, no?
noit wasnt, look at it. no mention of the spa updates on this sites link.Confused_Andy wrote:You know that was a feature on this very website... Its not updates at spa either.
http://www.f1technical.net/features/15369
Both links are from the same reliable author. He does not confuse easilyConfused_Andy wrote:Correct, but the site above my link has just used the imagery from this site and said that they were spa updates even though they are not...
You're quite right, you're not allowed more than 2 closed sections in the rear wing (except the central exclusion area). The picture shouldn't show daylight flowing through one of the slots, as actually from the front the wing is only 2 parts and ventilates the extra slot gap through slots in the lower part of the wing. See photos of this, and possibly last years, Mclarens at Monaco to see what I mean.747heavy wrote:I´m not sure if this wing on the left would be legal in 2010, as it shows three elements?
and I´m under the impression that you are only allowed a two element wing in 2010.
I´m wrong?
