It's more the fans who want it I think. Something like 70% of viewers would prefer crystal clear picture.andrew wrote:As long as F1 is still available in the current format it can have as high a definition as Bernie Ecclestone wants.
Further to that, one of the guys I work with has an HD TV (and watches the F1!). They actually said to me that there is no real difference in the picture on the HD TV and the regular TV. A slightly sharper picture but by the sounds of it not really worth going to the expense of by a new TV just yet.segedunum wrote:The fans might buy into the hype of HD, but given that most HD pictures are merely upscaled people who get HD and see it then wonder what all the fuss was about.
They've been right so far in the the hype simply hasn't justified the cost or income.
The truth is, other than the Sky watermark and the text overlays, if the SD signal of the races is much worse than the HD one is because the upscaler in your TV is not up to scrach. Which I would doubt in a 46" TV.WhiteBlue wrote:Sky brings the upscaled version both in SD and in HDTV. If have subscribed to their HDTV option and I have the choice which signal I want to watch. I must say the SD is really inferior on my 46 " Samsung LED set. So I look much forward to get an even better picture mainly from the in race and on board cameras. The stuff they use for the interviews is already quite high in resolution.
I'll call bullsh!t on this one. The difference in transmitted detail is remarkable and the upscaler in my TV is extremly good. The explanation is that FOM obviously transmits in higher resolution than PAL SD and the broadcasters scale it down. For HD they obviously scale it up and the difference shows if you have an opportunity to compare directly.Miguel wrote:The truth is, other than the Sky watermark and the text overlays, if the SD signal of the races is much worse than the HD one is because the upscaler in your TV is not up to scrach. Which I would doubt in a 46" TV.WhiteBlue wrote:Sky brings the upscaled version both in SD and in HDTV. If have subscribed to their HDTV option and I have the choice which signal I want to watch. I must say the SD is really inferior on my 46 " Samsung LED set. So I look much forward to get an even better picture mainly from the in race and on board cameras. The stuff they use for the interviews is already quite high in resolution.
EDIT: If you're talking about SD then you're right. Since FOM doesn't actually shoot in HD then the SD output is being made worse somewhere along the line, and it's usually the poor upscaler and SD handling in the majority of TVs.Miguel wrote:The truth is, other than the Sky watermark and the text overlays, if the SD signal of the races is much worse than the HD one is because the upscaler in your TV is not up to scrach. Which I would doubt in a 46" TV.
How do you know if you haven't seen the raw transmission itself and have only ever seen it through your TV?WhiteBlue wrote:I'll call bullsh!t on this one. The difference in transmitted detail is remarkable and the upscaler in my TV is extremly good.
a) I need glasses, but with them on I see quite well, thank you very muchPup wrote: But, true HD with reasonable compression is not just noticeably better, but dramatically so. Anyone who says it isn't either:
a) needs glasses,
b) has never seen good quality HD, or
c) is a sour puss.
Yeah, I think I wasn't in the right mood to watch Avatar. It also seemed to have quite a few parts consisting of "oh, look, we can do HD and vibrant colours too!". I'll also add that I hadn't seen the movie before, although maybe the review at Ars Technica and, more importantly, this.Pup wrote:So, "c" then.
You seem to have expected HD to turn Avatar into a good movie. It just doesn't have that kind of power.
