I think it is the opposite. Because less oxygen is available, hence reduced power, the teams might choose to increase RPM to compensate for the slight drop in power. Therefore working the engine harder.JohnsonsEvilTwin wrote:Less oxygen means less combustible fuel, therefore from my amateurish deduction I would say ever so slightly easier.
I agree.djos wrote:F1 has always had team orders, most of the time they are more subtly implemented and we dont know about them - it's all part of the sport.imightbewrong wrote:So, to summarize: You think it is OK to "cheat" as long as you don't get caught.djos wrote:Ferrari broke them openly, RB would hopefully learn from Ferrari's mistake and tell the drivers before the Race what do do in what situations and prolly use more subtle codes to remind them during the race.
Btw, Nando will be on the podium but a 1-2 seems unlikely unless it's a Red Bull 1-2!
Correct?
Add to that that less dense air is less able to convect heat away, so cooling could also be an issue, although recent races at interlagos tend not to have too high an ambient temperature, and often feature rain, so that could very well negate my comment!freedom_honda wrote:I think it is the opposite. Because less oxygen is available, hence reduced power, the teams might choose to increase RPM to compensate for the slight drop in power. Therefore working the engine harder.JohnsonsEvilTwin wrote:Less oxygen means less combustible fuel, therefore from my amateurish deduction I would say ever so slightly easier.
Plus I remember Martin (not sure) mentioned during the commentary that Brazil is "quite hard on engines".
I think the way it works is that there is less/thinner air at altitude so engine performance is reduced.Gerhard Berger wrote:So this race is at altitude, is this harder or easier on the engines?
I wonder if all engines will suffer the same reduction ratio?Sean H wrote:800 meters above sea level. Williams estimates it could be as much as 7-8% reduction in power.
The reduction in power would be the same for all engines. Why would it be different?forty-two wrote:I wonder if all engines will suffer the same reduction ratio?Sean H wrote:800 meters above sea level. Williams estimates it could be as much as 7-8% reduction in power.
For example, what if the Cosworth guys lose only 1% while the Renault guys suffer 9%? That could be interesting!
i think renault motor is one of the best in F1. maybe dosnt have strong power, but his efficiency and lower fuel consumption this compensated.forty-two wrote:I wonder if all engines will suffer the same reduction ratio?Sean H wrote:800 meters above sea level. Williams estimates it could be as much as 7-8% reduction in power.
It could be possible one engine may be more susceptible to less apparent oxygen than another? I'm not an engine guy, so it may be a negligible difference, or make no difference at all.GTO wrote:The reduction in power would be the same for all engines. Why would it be different?
