I thought you used Planck's constant on a daily basis JT, when you're the one who mentioned it in the first place?
But tell me now, what do you need Avogadro's number for then?
This is not the case.riff_raff wrote:The only characteristic of a tire that would change after "scrubbing" is maybe the tread rubber compound's durometer. The internal fabric plies and bead would not be affected. So the tensile structural properties, which are mostly dependent upon the fabric properties, would not change much.
Well, if you don't care about your credibility and simply xpect members to take your statements for granted, however un-engineerish they come across, just because you claim to be working with tyres, I guess we have a problem then?Jersey Tom wrote:My credibility here is something I couldn't care less about Tires are what I do for a job. I can't elaborate on much past basics and "common" knowledge because it's professional information I don't care to share.
Suffice to say, a tire definitely changes from when it's brand new to when it's broken in to when it's got some miles on it. More than just the modulus or hardness of the tread.
If you don't believe me, take some tires to DaveW and do some springrate work. What's the tire rate when it's new? With a few lap scrub? After 40 laps?
