machin wrote:Isn't the L/D ratio of a low incidence aerofoil better? A higher speed means a lower incidence angle can be used for a given lift and that means less drag?
For experimental use and models a suitable aerofoil section and angle can be designed into an unpowered rotor with ease (unlike a powered rotor).
Of course the angle will vary around the disc, depending on airspeed, which cannot be achieved with fixed wing other than in a crude sense with pitch angle.
It should be possible to design an aerofoil section to give a constant high efficiency through a range of rotor airspeed and airflow angles.
The problem is the lack of suitable computer simulations containing the research data done at BAE Bedford by Ken Wallis using the Concorde laboratory, using a real autogyro in flight.
The CAA used Glasgow University who had nobody available who had ever flown or worked on autogyros. They constructed computer models that are frankly wrong and the CAA based their limited regulations on this incorrect data. A joke.
