Easy there x, i think this is a very interesting discussion, no need to disregard people like that. Remember, as much as you got used to it, you're not arguing with WB here, hopefully you're not missing himxpensive wrote:... I'm actually surprised to have this discussion with someone who claims to work with tyres, but then again, I never met an engineer who uses both "Planck's constant" as well as "Avogadro's number" in his job?
I think in the end this comes down to which concepts are being discussed, i for one understand JT's argument quite well, all load must necessarily reach the rim through the sidewalls bead.
On the other hand you're right with the contact patch/pressure thing. I don't see how these two things contradict each other. Perhaps you can explain what it is you have a problem with regarding JT's point?to
