I do not know if all of you have a copy of 2006 regulations. They are entertaining to read...
Let's compare the rules (
http://www.fia.com/resources/documents/ ... ATIONS.pdf) and the comments we made.
joseff wrote:If you make the wings too rigid, they'll crack. CFRP is very brittle.
3.4.3 In order to avoid the spread of debris on the track following an accident, the outer skins of the front wing, endplates and any turning vanes in the vicinity of the front wheels (and any similarly vulnerable bodywork parts in this area),
must be made predominantly from materials which are included for the specific purpose of containing debris. The FIA must be provided with details of the way in which all such parts are constructed.
m3_lover wrote:It is suggested that the Maranello based team's wing can 'flex' at high speed, and that while it may pass the specific FIA tests, it is designed to flex only in areas that are not tested by the stewards.
3.17.7 In order to ensure that the requirements of Article 3.15 are respected, the FIA
reserves the right to introduce further load/deflection tests on any part of the bodywork which appears to be (or is suspected of), moving whilst the car is in motion.
peroa wrote:auto motor und sport reports that the besides the wing there is also complaint about the carbonrings on the outer side of the rims. Now listen to this: the stewards declared this rings as part of the braking system!
![Eh? :-s](./images/smilies/icon_eh.gif)
1.19 Brake caliper :
All parts of the braking system outside the survival cell, other than brake discs, brake pads, caliper pistons, brake hoses and fittings,
which are stressed when subjected to the braking pressure. Bolts or studs which are used for attachment are not considered to be part of the braking system.
m3_lover wrote:According to 'Auto Motor Und Sport' in Germany, the Renault's 2006 rear wing is designed so that - at high speed - the trailing edge moves out of the line of wind flow. A central theme of the 'flex' case against Ferrari, meanwhile, is that - unlike every other team - the main element of the '248' car's rear wing is not reinforced by vertical 'supports', which in theory could allow the wing to bend at high speed.
3.17.5 The uppermost aerofoil element lying behind the rear wheel centre line
may deflect no more than 5mm horizontally when a 500N load is applied horizontally. The load will be applied 800mm above the reference plane at three separate points which lie on the car centre line and 250mm either side of it. The loads will be applied in an rearward direction using a suitable 25mm wide adapter which must be supplied by the relevant team.
3.17.6 The forward-most aerofoil element lying behind the rear wheel centre line and which lies more than 600mm above the reference plane
may deflect no more than 2mm vertically when a 200N load is applied vertically. The load will be applied in line with the trailing edge of the element at any point across its width. The loads will be applied using a suitable adapter, supplied by the relevant team, which :
- may be no more than 50mm wide ;
- which extends no more than 10mm forward of the trailing edge ;
- incorporates an 8mm female thread in the underside.
I agree with DaveKillens. Rules are made to be studied and you have the duty of make them work in your favor. And if we have the privilege of enjoying all their efforts, why not do it with a little humor? Instead of fight each other we can make fun of each other. Let's get ready to rumble...
Finally, if you were organizing a rock concert and the Rolling Stones were playing and you refuse to bend a little the rules in their favor... what are you? a rock fan? or a smart ass? Well, it is the same with Ferrari. And (before Manchild reads this) I am not a Ferrari fan. I may not agree with the stewards, but I understand them. I have been one in Colombia (in Formula Renault races...
![Embarassed :oops:](./images/smilies/icon_redface.gif)
