Just out of curiosity, as there was a discussion on the board, back at the days when the RA107 was raced.
What´s the wheelbase and the trackwide (centre/centre of wheel) for the car?
If you did not measure it, and have it all apart now, don´t worry it´s not that important.
No need to spend hours to put it back together.
It could just help to see the possibility of a complete rear-end transplantation from another car.
An F3000 Lola would have a wheelbase of 3000mm, from the information floating around a SA2007 where said to have ~3135mm and the RA106 3140mm wheelbase.
Seeing, that the "bellhousing" of your gearbox is quite long, you may end up, with the same wheelbase and 50-80mm to spare between your tub and the F3000/GP2 rear end. This space you could use for an adapter to link the mounting points of you tub/chassis with the mounting points on said engine.
Also allowing for a slight offset in height of the new engine to counter the clutch diameter/crankshaft height problem.
Don´t get me wrong, I´m not trying to sell you on the rear-end swap idea.
But depending on your main aim, it could be the fastest way to a drivable car, where you can go and "scare yourself with".
Let´s be honest, the car will never be "original" unless you get a original engine for it.
I have huge respect for your aim and undertaking, put very frankly to attempt to either try to use the complete original gearbox, or to build a custom made gearbox/gear cluster into the original casing, is a huge project.
The first one, would require indeep knowledge of the control system/logic used by Honda, and is maybe difficult to replicate with a different controller unit.
It´s not impossible, but a huge challenge.
Keep in mind, that a crash/or other damage to the gearbox or casing could spell the end to the whole project, if there is no replacement available.
Depending on your aim/priorities and budget, I would at least take a look at a complete rear-end swap. It´s easy to do, and if you find, that it does compromise he original look of the car to much, or is too expensive, you can still do something else.
I´m sure, if you call around a bit, you will find someone with an ex F3000/A1GP/GP2 car, roll the complete rear-end behind your chassis/tub and have a look, how much of the bodywork/floor/diffusor would still fit?
To get somebody to make a set of steel wishbones and cover them with some carbon fibre fairings could be less of an challenge then trying to built your own gearbox internals or step gear - IMHO
You would get a proven and matched engine/gearbox unit, with all the electronics and control systems in place.
Gear ratio´s (for different tracks etc.) would be widely available as well.
To connect and wire your other sensors (throttle position, G-force, brake pressure etc.) to such a controller/ECU and connect a display would be fairly easy, compared to the task of developing your own gearbox controller for the Honda gearbox.
Keep in mind, that the original Honda gearbox was designed with the power/torque characteristic of the Honda engine in mind.
Even if you get it to run/shift gear, chances are high, that the gear ratios will not work well with your chosen engine (which most likely will be less powerful).
And getting different gear ratios for this gearbox, could prove difficult.
In any case, all the best for your project, whichever way you may go.
I have respect and admiration for your attitude towads this project and hope you succeed one day with it, and get the pleasure to run it, or see it run on a track.
All the best
747h
P.S.: from the informations on the web. (right or wrong? dunno), the Gp2 car would have a wheelbase of 3119/3120 mm
http://en.wikipedia.org/wiki/GP2_Series
http://arden-motorsport.co.uk/page.asp? ... o/GP2-Car/
dimensions F3000 Lola
