Team: Stefano Domenicali (TP), Mario Almondo (Director of Operations), Aldo Costa (TD), Nicolas Tombazis (CD), Luca Marmorini (HE) Drivers: Fernando Alonso (5), Felipe Massa (6)
F11 sounds like a very "tinny" word. It doesn't roll of the tongue nicely, nor sounds as aggressive or "woody" as F10.
[youtube]http://www.youtube.com/watch?v=-gwXJsWHupg[/youtube]
ringo wrote:F11 sounds like a very "tinny" word. It doesn't roll of the tongue nicely, nor sounds as aggressive or "woody" as F10.
In Italian it sounds nice. Besides, in such a fine environment I don't think they actually want woody names for the most part.
I've been censored by a moderation team that rather see people dying and being shot at terrorist attacks than allowing people to speak the truth. That's racist apparently.
How will the Ferrari 2011?
Whoever has seen at Maranello ensure that the new machine will be completely different from the Ferrari F10. In short, that this year should be an all-new Ferrari, even visually.
It will be the new livery but will also revolutionized new aerodynamically. This revolution will not be adopted only for the regulations, for instance, the disappearance of the large sail on the hood, replaced by a smaller fin and no longer connected all'elettone back (eg F2008).
The car that we will see the presentation on Friday will not show many of the new changes. We already know that the car Friday mount the wings and rear of the F10. In this configuration will also run at Fiorano with Fernando Alonso, on Friday afternoon or Saturday. The new wings will be seen only at the Valencia test, which will begin Feb. 1.
Rumors speak of a Ferrari revolutionized aerodynamically and is ready to use two technical solutions already adopted successfully by Red Bull:
- A high nose, wide and flat, "hollowed out" in the lower
- Pull-rod suspension at the rear
Despite all the complications related to the use of KERS, Ferrari realized that the road to success passes mainly aerodynamic efficiency.
Because the muzzle-style Red Bull?
One of the main aims at the technical level for the 2011 season is to recover the lost downforce at the rear after the disappearance of the diffuser.
It 'also need to rebalance the entire car because the static weight distribution has been fixed by regulation. In the front, the current F1 and load have too compared to what you can get behind. For this reason, in recent months in the wind tunnel, we have studied a solution with a high nose and flattened as the cars designed by Newey. As we know, the 2011 technical regulations, has established a limit on the elevation of the "nose" than the level of the passenger to try to avoid penalizing the visibility. High nose, it means a pretty carved and arched frame at the bottom, so as to leave as much space as possible below, in order to allow a greater flow of air to the rear. This will help the speaker to work in the best way retrieving cargo at the rear.
Because the pull-rod suspension?
Ferrari last year had already seen a return to the pull-rod suspension, or rod for the F10. That solution was then discarded from complications due to the presence of the diffuser.
What is the difference between pull and push-rod-rod?
In the first, the spring-damper is located at the bottom, and the movements of the wheels are absorbed by a rod that works in traction, lashed down to the gearbox and at the top of the wheel.
In the push-rod, the group is up and absorbing the vibrations are transmitted by a strut, a rod that is pushed by the wheel, from bottom to top.
With the disappearance of the double diffuser, is forced to come back with extractors and low volumes have to be used differently in space. For this reason, the pull-rod solution becomes convenient as it allows to bring the weights down, helping to balance the car, goes well with a discharge in a lowered position, giving less heat problems.
donskar wrote:@csponton -- source for your post? Did I miss something? Very interesting, I'm just wondering about how accurate it might be . . .
I love this:
"Revolutionized aerodynamiclly" by copying Red Bull?! I'm OK with that. Red Bull provides a proven starting point.
My personal sources. The aerodynamic concepts are those of Red Bull but will be further developed with new solutions.
The day on which the rear end will not be the definitive one because Ferrari will keep him hidden until the end.
Scuderia Ferrari's 2011 F1 car will be called F150, the famous Italian team has announced. The car, to be launched and given its track debut on Friday at Ferrari's headquarters, is named in tribute of the 150th anniversary of Italian unification.
I've removed the posts poking fun at the name of this car. I had a really good laugh but I don't think it's all that great to have in here for future reference. The posts can now be found in the 'completely out of thread' thread in the OT section.
