kilcoo316 wrote:
Erm. Thats on two co-planar surfaces.
The important bit is me ballsing up the negative 0.5 *rho *V^2 (and its not the first time I've done that either!)
What I believe is the important thing to remember is that the total pressure is kept constant through a passage (bar the losses), such as between the F1 car's floor and the road, why the static pressure will decrease when dynamic pressure increases with the air-speed, which produces a static pressure differential vs the top of the car where air-speed is slower.
That static pressure differential times air-passage area, is what creates your down-force, why everything you do on and around the floor/diffuser, vortexes and what have you, aims at increasing air-speed under the same floor and really not much else.
I actually played with some numbers two years ago, here:
viewtopic.php?f=6&t=6545&hilit=importan ... e+diffuser
Btw kil, remember to multiply your "centistokes" with density times 10^-6 before your calc's and you be ok.
