Mercedes GP W02
Nuclear
Nuclear
Re: Mercedes GP W02
According to AMuS Live Ticker the W02 has a new Front and Rear wing attached
JohnsonsEvilTwin
Re: Mercedes GP W02
Standby for pics
Here we go...not the best angle....
More could have been done.
David Purley
Raptor22
Raptor22
26
Re: Mercedes GP W02
indeed the upgrade does apear to be working rather well with Schumacher running around .3sec slower than Webber while fueled for a midlength stint.
Maybe just maybe Mercedes are in better shape than the detracters would have us believe.
If the car has constistency I'd expect Michael to be ruffing it with the front runners. Britney seems more timid with wheel to wheel battles
Mandrake
Mandrake
Re: Mercedes GP W02
JohnsonsEvilTwin wrote:Standby for pics
[img]http://www.f1today.nl/foto.php?file=12090[img]
Hey JET, in your picture, is there still burnt paint on the engine cover?
Look closely at 20cm right of the gills, it seems to me that there is burnt paint. Does the exhaust go backwards first and then bends forward?
kris
kris
Re: Mercedes GP W02
Nuclear
Nuclear
Re: Mercedes GP W02
Slotted Front wing =D> + Another Wing attached to the upper small "shovel"
maestro272
maestro272
Re: Mercedes GP W02
Do I see it right?The wing is flexing?
raymondu999
Re: Mercedes GP W02
New front wing cascade: Pardon the small reso
失败者找理由,成功者找方法
zgred
Re: Mercedes GP W02
LoudHoward
LoudHoward
Re: Mercedes GP W02
maestro272 wrote:Do I see it right?The wing is flexing?
Looks like body roll mainly. Doesn't look like a particularly fast corner anyways.
maestro272
maestro272
Re: Mercedes GP W02
That's exactly what I've thought. Some fast corner photo would be nice.
bot6
bot6
Re: Mercedes GP W02
If you look at the angle between the left and right part of the wing, it's definitely flexing.
Disappointed with the shape of it though, apart from the bending it's just the old one with a tiny slot...
Raptor22
Raptor22
26
Re: Mercedes GP W02
Correct, its body roll due to the lack of rear springs on the modern cars.
they design the upper suspension arm to provide the "spring" and only run dampers. Spring rate is altered by a air chamber on the damper. These units are much smaller and more compact than the older coil springs or more recent torsion bar
the teams do this to make the rear end more supple and that provides better traction.
With the smaller diffusors in use this year there is no need for a very stiff rear end since the flow is not as affected as last years double diffusors when the rear of car rides up and down on bumps.
kris
kris
Re: Mercedes GP W02
Is there a new inverted L shape on the Front wing elements? (seen on the left side near the petronas lettering)
maestro272
maestro272
Re: Mercedes GP W02
bot6 wrote:If you look at the angle between the left and right part of the wing, it's definitely flexing.
Don't forget even small changes on FW can make some notable difference
