viewtopic.php?p=166170#p166170
As we have seen it is sufficient that the infra structure around a power plant is destroyed by a catastrophe and the decay heat will destroy most reactors due to lack of cooling. Whether the destruction comes from military weapons, natural disaster, terrorist attack or aircraft accidents doesn't matter in my view.WhiteBlue wrote:Of cause Nuclear energy produces no global warming gases, but that doesn't mean at all that the production of nuclear energy, the handling of nuclear fuel and the associated waste is good for the environment...Ciro Pabón wrote:As nuclear energy does not produce global warming gases, it is better for the environment (I mean, for me and you). We already discussed this theme and it seemed to me that after reviewing the figures, the forum agreed that the way to go is nuclear.
There are examples of nuclear reactor accidents caused simply by their building collapsing from material fatigue. The more we have to be concerned that far more dangerous reactors like the sodium cooled fast breeders can be hit by aircraft terrorist attacks, earth quakes or even plain stupidity in civil wars.
Countries with the social stability of Iran are building reactors and who knows what dumb sh!t in possession of a tank or howitzer may decide to blast some holes in a nuclear facility? California, Japan and a bunch of other states with active volcanoes and regular earth quakes are building reactors happily without a thought of the wider consequences...
Today's operating reactors are mainly big water cookers with temperatures of 200-300 °C and based on technology that is fairly well understood. Nevertheless these rather simple plants can be effed up as Chernobyl shows. The future reactors will mainly be breeders with design technologies that are unproven or undeveloped and on temperature levels of 800 °C. The coolant will not be water that carries limited contamination and destructive potential but liquid sodium that ignites in contact with air and water and can easily blow up a nuclear core in a case of ignition. All prototype breeders with sodium cooling have had coolant leaks (due to high temp corrosion) and some even coolant fires. One dumb guy with a rocket propelled grenade can blow up the secondary sodium circuit which isn't usually protected by the containment and the whole plant including the core goes up in the air. Future breeders will use some 6000 tons of liquid sodium. I leave it to someone else to figure the equivalent of TNT but I tell you we are not talking fire crackers here. A breeder reactor can go critical if the grid power is lost for some reason for half an hour and the back up generators do not kick in. The reactor relies on the big sodium pumps running to circulate thousands of tons of liquid metal through the heat exchange circuits. .
This accident series in Japan simply demonstrates that it is almost impossible to protect against all configurations of disasters that can impact on this inherently dangerous technology. My opinion remains the same. Get rid of the nukes and particularly the breeders.
