speedsense wrote:
So this isn't about the MP4-26? Two different camera angles, showing the same thing, interesting that none of the other parts on the car have an "illusion" just the parts that can be adjusted up or down, interesting....
I would have concurred on the Illusion aspect on one photo, but not two.....
And to top that, the vanes on the inside of the diffuser (not the wing end plates vanes, as pointed out by others) are missing on the left side of the car and there are two on the right side.. more asymmetry on the MP4-26? You'll need to blow up the picture for this... another illusion? Not hardly, None of the three pictures is an illusion...
I'm sorry. But they are optical illusions. The last one is easily provable if you just zoom in. You can see one of the vanes between the slits on the end plate. But here, I made a picture for you, actually showing it.
Now we can all agree that pictures can some times fool you? Well, now put on some parallax and you got the illusion of an asymmetric front wing. Here, put some reference lines in for you between reference points. Doesn't look so asymmetrical now, does it?
![Image](http://i.imgur.com/cOjEF.jpg)
