Gotcha, so basically, whatever points were associated with a car running said illegal parts. Regardless of the time frame.
timbo wrote:A test is a test and the wing passed — there's no breach of existing regulations.
Yes they passed that one test but what I'm saying is what if they devised a test that could allow them to inspect the following (what bot6 pointed out in the wing flex thread):
3.15
Aerodynamic influence :
With the exception of the driver adjustable bodywork described in Article 3.18 (in addition to minimal parts solely associated with its actuation) and the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance :
- must comply with the rules relating to bodywork ;
- must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom) ;
- must remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances.
No part having an aerodynamic influence and no part of the bodywork, with the exception of the skid block in 3.13 above, may under any circumstances be located below the reference plane.
3.17.8
In order to ensure that the requirements of Article 3.15 are respected, the FIA reserves the right to introduce further load/deflection tests on any part of the bodywork which appears to be (or is suspected of), moving whilst the car is in motion.
So they come up with a test rig, do the test, see the flex, then can they prove the same wing was used prior to that inspection? (might be a moot point, those rules are kind of vague really and everything flexes a little, even the more rigid wings on the rest of the cars).
Anyway, for example what if they FIA didn't have their test ball with them at Australia to inspect Sauber's flap radius, but instead checked it one or two races later. Would they DQ just that race result or all races prior where they were using the flap in question?
