You can see the diffuser is significantly higher off the ground than the MacMerc in front and the actual front wing height looks pretty similar on this angle.
Hmm, I guess my pic merely confirms the RB7 has very soft suspension then?mx_tifosi wrote:What doesn't work in your observation Djos is that the McLaren is exiting the curve while the RBR is halfway in. The McLaren is accelerating thus squatting, while the RBR is still diving thus the differences in diffuser height. IMO.
The screenshots of the RBR and Ferrari in the same section of the straight prove that their front wings do flex more than the rest. It's hardly an arguable subject at this point in time.
I agree with you. However, some pics posted here seem to show that rbr front wing has an higher incidence than what coming from car body rake. I think it could be either of these two:Ciro Pabón wrote:You don't have to change angles of attack (even if they change) to get an advantage of the front wing bending. Just the diminished ride height is enough to provide you more downforce.
Agree with you that other teams seem not to be on the same level of mastery (hiding in the word mastery everything from trickery to top end technology); seems very strange to me that they have not found a way to reach the same level (considering also that a lot of people change team every year).Ciro Pabón wrote:About why other teams haven caught up with RBR, I insist that the trick needs a wing that is not elastic, but plastic or thixotropic. That must be quite a trick and requires research.
Could you explain a little more about what you mean there marekk? Do you mean that the pressure distribution is changing with more rake? More to the leading edge of the floor and less to the diffuser? Overall though, with extra rake angle you'll get extra DF from the floor, right?marekk wrote:But with more rake you loose diffusers efficiency...
I think RB7's DRS is designed, like the whole car, with pole position and lap time in mind - they don't bother that much with DRS as overtaking device, and they loose not that much downforce/drag with DRS activated.marcush. wrote:but:rake will also give you a downforce peak at the leading edge of the tea tray...and Vetel chose to run a lot of the time with the drs deployed so the car seems to be planted at the rear as well....
More rake = more downforce at floor's leading edge for sure, but less at diffuser's leading edge (bigger gap to the tarmac = less speedup of the flow).horse wrote:Could you explain a little more about what you mean there marekk? Do you mean that the pressure distribution is changing with more rake? More to the leading edge of the floor and less to the diffuser? Overall though, with extra rake angle you'll get extra DF from the floor, right?marekk wrote:But with more rake you loose diffusers efficiency...
