Turkish GP 2011 - Istanbul
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
Circuit information
Length: 5.338km
Race distance: 58 laps / 309.356km
Full throttle: 63%
Top speed: 315kph
Longest flat-out section: 16s / 1.2km
Right/left-hand turns: 6/8
Tyre wear: Medium/low
Brake wear: Medium
Downforce level: Medium/high
Gear changes per lap: 42
Tyres
2010 tyre compounds: hard (prime, no marking), soft (option, green markings)
2009 tyre compounds: hard (prime, no marking), soft (option, green markings)
2008 tyre compounds: hard (prime, no marking), medium (option, white markings)
Average fuel use per lap: 2.658kg/lap (source: Williams)
Pit lane time loss: 18.5s
2010 Result
raymondu999
Re: Turkish GP 2011 - Istanbul
Methinks tyres will be even more problematic due to the infamous T8
失败者找理由,成功者找方法
volarchico
volarchico
andrew's "2010 Results" images don't show for me, so if this is already covered, delete the post:
2010 Qualifying:
P1, Webber 1:26.295
Lap record:
1:24.770 - JP Montoya (2005)
Turkey dreams.... Mclaren one two!
MrBlacky
MrBlacky
Let's see if Mercedes can do it better this year.
Gerhard Berger
Gerhard Berger
-1
I think Vettel will win and still run away with this championship. He would have won today quite comfortably if he had 3 stopped.
Exactly what I think as well. It was a lucky escape for Mclaren today.
raymondu999
Well strategy is part of the game, and I don't think McL was lucky in terms of them 3-stopping. That was good on them. BUT I will give it to them that RBR had the brainfade (or radio error) that meant they stayed on the 2-stopper with Seb; they were lucky in that respect.
失败者找理由,成功者找方法
Shrieker
Last time in Istanbul... Hope it produces an enjoyable race.
-Atatürk
With turn 8 on those Pirrellis it definitely will!
raymondu999
I was wondering. With T8 the way it is, how likely is it that in an attempt to help with the front right's wear, some teams actually start to adopt positive camber on part of their setup?
失败者找理由,成功者找方法
Well positive camber is a bit over the top, but I sure think they take T8 into their setup giving it a bit less camber for example.
raymondu999
I would've thought you would need positive on the Front left and negative on the front right if you wanted a setup geared completely for T8 tyre preservation
失败者找理由,成功者找方法
JohnsonsEvilTwin
raymondu999 wrote:I would've thought you would need positive on the Front left and negative on the front right if you wanted a setup geared completely for T8 tyre preservation
It will be a compromise. Setting up for turn 8 allows you an overtake opourtunity the next couple of corners. But it wil hinder you on the slower last couple of corners if you have set up to much for the faster left hander. With Pirelli bringing softer tyres and the actual ambient heat expected to be higher, we could see a 4 stop race being the norm here.
Even cars that are kind on their tyres will still not be able to do longer stinits without suffering slower lap times as we saw today.
Basically, no one is safe! :lol:
More could have been done.
David Purley
raymondu999
No no, I'm not talking about setting up for speed through Turn 8. I'm talking about minimising the wear that is experienced through Turn 8.
失败者找理由,成功者找方法
