Williams FW33
shelly
shelly
136
Re: Williams FW33
Diesel wrote:Proves conclusively that copying a single component doesn't work in Formula 1.
Or proves that in two fp sessions they have not found the grips with the system yet.
AFAIK, exhausts are very difficult to simulate: almost impossible in wt, erratic in cfd. They may need some on track tuning
twitter: @armchair_aero
i70q7m7ghw
i70q7m7ghw
49
Re: Williams FW33
As I said in another topic, understanding the concept is more important than applying it.
shelly
shelly
136
Re: Williams FW33
I know, but in this case you have to apply it in order to understand it
i70q7m7ghw
i70q7m7ghw
49
Re: Williams FW33
Touche :P I do agree with you, I just want to stop all of this "copying red bull makes you go fast" talk that seems to keep cropping up.
Alexgtt
Alexgtt
Re: Williams FW33
Took McLaren quite some time to understand and optimise it. Williams just need time.
dren
227
Re: Williams FW33
Alexgtt wrote:Took McLaren quite some time to understand and optimise it. Williams just need time.
Agreed. It took several teams several races last year to get it to work right.
Honda!
240
Re: Williams FW33
Diesel wrote:Touche :P I do agree with you, I just want to stop all of this "copying red bull makes you go fast" talk that seems to keep cropping up.
Where would they be if they never copied it?
copying redbull eventually makes you go fast. :wink:
Formula None
Formula None
Re: Williams FW33
MGU:
KERS radiator:
Battery:
raymondu999
Re: Williams FW33
The car was good in pre-season, and flopped when Melbourne started. Almost makes me think that McLaren switched their car with the Williams.
What do you folks reckon is the primary issue with this car? Is it lack of downforce? mechanical grip (which I doubt as they've always been mechanical kings along with McLaren in the past)? Tyre use? I mean, Barrichello is known to be a great car-developer and can find good directions in terms of both setup as well as car development, and even he seems to be out at sea on this one.
失败者找理由,成功者找方法
240
Re: Williams FW33
I think the tyre use, especially the rears is good.
The problem may be the wings. They seem a bit 2009. Not only that but it may well be the setup of the car.
Remember williams use to be friday practice pole position queens with Nico Rosberg?
They used to run the car very light in practice.
So their approach to setting up the car with the pirellis and fuel may be wrong, similar to mercedes who just now realized they were taking the wrong approach fuel weight wise with learning the tyres.
Wings and practice procedure. The skirted diffuser is the other thing, but isn't a fundamental problem.
Formula None
Formula None
Re: Williams FW33
ringo wrote:I think the tyre use, especially the rears is good.
Obviously they are having issues ingesting leaves & grass into the brake ducts. The only way this can be fixed is to apply more rake to the track. Only then can they remove the duct screens and gain 11 tenths in race pace.
Francesc
Francesc
50
Re: Williams FW33
You're wrong I'm afraid.
Traction is said to be very poor, due to the Cosworth driveability, so the rear tyres go off early.
DRS flap is too big, so they lose performance in Qualifying.
They have quite alot of rear downforce, but they don't have a front end to match it, hopefully the new front wing that is coming for Turkey will solve that.
horse
Re: Williams FW33
Do you think this is why they scrapped the RB style exhaust because adding more down force at the rear is fruitless if the front is weak?
sink
sink
Re: Williams FW33
If that were the case, I'd guess they would rather take off some wing to compensate.
marcush.
marcush.
159
Re: Williams FW33
compare the size of the parts to mclaren 2009:
btw the MGU looks more like a big pump to me with all the tubes for coolant flow...and how does the thing bolt to the engine? no mounting flange ?
btw :MGU in Porsche GT3Hybrid applikation:
