2001 Bentley EXP Speed 8 LMGTP
High downforce configuration:
Downforce:
3094 lbs. @ 150 mph
4455 lbs. @ 180 mph
5500 lbs. @ 200 mph
Low downforce configuration:
Downforce:
2022 lbs. @ 150 mph, with 546 lbs. of drag
2911 lbs. @ 180 mph, with 787 lbs. of drag
3594 lbs. @ 200 mph, with 971 lbs. of drag
Lift-to-drag ratio: 3.70:1
Coefficient of drag: .5038
Coefficient of lift: -1.87
Reference area: 1.75 meters square
IMSA & Group C were known for having the highest amounts of downforce ever. Must have had amazing tires in those days (anyone have any info?):
2011 Dome S102i
Le Mans setup (i.e. low downforce):
Map average:
Downforce:
2737 lbs. @ 150 mph, with 666 lbs. of drag
3941 lbs. @ 180 mph, with 960 lbs. of drag
4865 lbs. @ 200 mph, with 1185 lbs. drag.
Lift-to-drag ratio: 4.10:1
Map average balance: 45.50%
Developed but not raced. Reflects the effects of the 2009-2011 regulations (narrow span and chord rear wing, domed skid ['09], rear fender regulations ['10], and big-honking-fin ['11])
Open wheel:
1991-1993 Toyota Eagle MkIII GTP
Image copyright Mark Windecker Debut variant:
Downforce:
3802 lbs. @ 150 mph, with 929 lbs. of drag
5476 lbs. @ 180 mph, with 1338 lbs. of drag
6760 lbs. @ 200 mph, with 1652 lbs. of drag
Lift-to-drag ratio: 4.09:1
Image copyright John Brooks Twin-tiered Bi-plane rear wing development, max downforce:
Downforce:
5217 lbs. @ 150 mph, with 1180 lbs. of drag
7513 lbs. @ 180 mph, with 1699 lbs. of drag
9275 lbs. @ 200 mph, with 2097 lbs. of drag
Lift-to-drag ratio: 4.42:1
Image copyright Greg Cooper Daytona configuration:
Downforce:
3617 lbs. @ 150 mph, with 723 lbs. of drag
5209 lbs. @ 180 mph, with 1042 lbs. of drag
6431 lbs. @ 200 mph, with 1286 lbs. of drag
Lift-to-drag ratio: 5.00:1
2001 Penske-Reynard-Honda 01I
A Road track configuration:
Downforce:
2750 lbs. @ 150 mph, with 924 lbs. of drag
3961 lbs. @ 180 mph, with 1331 lbs. of drag
4888 lbs. @ 200 mph, with 1644 lbs. of drag
Lift-to-drag ratio: 2.97:1
A Short oval configuration:
Downforce:
1675 lbs. @ 150 mph, with 725 lbs. of drag
2412 lbs. @ 180 mph, with 1043 lbs. of drag
2978 lbs. @ 200 mph, with 1289 lbs. of drag
Lift-to-drag ratio: 2.31:1
A Super-speedway configuration:
Downforce:
1000 lbs. @ 230 mph, with 950 lbs. of drag
Lift-to-drag ratio: 1.05:1
it is very possible that they do get more downforce.wesley123 wrote:because of those articles i think 12000N is a bit over the top.
Thereby, the lmp's do not got more downforce imo then open wheelers, their downforce is just more efficient, thus reaching a higher L/D
Amazing in what regard?Formula None wrote:IMSA & Group C were known for having the highest amounts of downforce ever. Must have had amazing tires in those days (anyone have any info?):
As the engine power and top speed (which means top drag) of LMP anf F1 cars are roughly the same, and L/D for LMP is WAY better then for open wheelers, downforce has to be much bigger - could be 1,5 to 2 times IMO.wesley123 wrote:because of those articles i think 12000N is a bit over the top.
Heavier car (relative to our open wheel friends, 800kg vs ~600kg)with potentially more downforce... Maybe they were constructed exactly the same way regardless, I don't know, that's why I was asking.Jersey Tom wrote:Amazing in what regard?Formula None wrote:IMSA & Group C were known for having the highest amounts of downforce ever. Must have had amazing tires in those days (anyone have any info?):
