Its just the reflection of the white pillar between the garages behind.astracrazy wrote:i see what you mean
not sure if its just the reflection but it does look like there more black and the silver is shaped more square/straight
beelsebob wrote:For a minute I thought they'd invented a hovering wing element off to the left!keoxiv wrote:Today:
Interesting that they don't feel the need for the curve along the trailing edge any more.
The 3 tunnels have always been there – interestingly, looking back at the launch pics, shots from the front seem not to show the curve on the trailing edge – I wonder if what I'm spotting is an optical illusion.avatar wrote:beelsebob wrote:[Interesting that they don't feel the need for the curve along the trailing edge any more.
The pylons have a very definite "twist" in them and looks a greater differencenon the spacing of the top and bottomnof the pillar to me. was that always like that..?
Not sure if its new, bur the ends of the wing have 3 steps/tunnels, the one that seperates the inside wheel/outside wheel flow (been there a long time) then a split (new?) seemingly mid-wheel that overlaps the base of the end plate (for more "droopy ends"?), the endplate base, then has the customary "tunnel" on it's outer edge.
No it's not, only the left hand side has the magical hovering extra wingletavatar wrote:tunnel 2 (vs launch) no longer butts against the endplate upright.
Probably made the tunnel appear more pronounced, so I noticed it.
not sure about the optical illusion without another angle,but at lesst it's symmetrical
I dont think so...unless there are now 0 slots in the end plate now!! There has been only 1 endplate hole for sometime now, back as far as Aus for surebeelsebob wrote: also seems to be one fewer slots on the end plates.
