Tozza Mazza - F1 Car Design
Tozza Mazza
Re: Tozza Mazza - F1 Car Design
Sorry bout the slow reply. Slots are allowed in the central 150mm of the car, whether it be in the beam wing or the main elements of the rear wing. The idea is that the top section of the flexi wing flexes the 20mm required for the load test under 100N of force, guaranteed by the lowered endplates, but under the greater force on the track, pushes the tunnels down closer to the track, harnessing ground effect, to some extent.
TM.
Tozza Mazza
Hello all, I know it's early, but I've began work on my 2012 F1 car, this time in painstaking detail, with the aim of accquiring CFD to improve my design and continue to refine it. It's still very early days.
For now at least, work so far can be found here :http://project-zero-pz-02.blogspot.com/
Thanks, TM.
