Flexible wings 2011
JohnsonsEvilTwin
Re: Flexible wings 2011
It's good you've never heard of it, because it appears no one has actually mentioned anything about material being added.
As I did say it was "restoring the profile" which in essence means shape, why would the need to add anything if the shape would easily be retained by sanding the bits that were ground out of shape....?
More could have been done.
David Purley
Dragonfly
Dragonfly
Try to answer yourself to your own question.
Spa 2012
JohnsonsEvilTwin
Dragonfly wrote:Try to answer yourself to your own question.
Excuse me?
Did you not ask the question yourself on the post previous to my last one?
Dragonfly wrote: I've never heard about restoring lost material by sanding the worn out part ...
because to restore the profile you have to replace the missing amount of material.
Adding material is not the only way to restore the profile my friend.
David Purley
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
JohnsonsEvilTwin wrote:Adding material is not the only way to restore the profile my friend.
Actually it is. Whilst the new profile may be the same shape, it would not be the same dimensions as the original and would in all probability not provide the desired aerodynamic properties.
It depends how you define restoring the profile.
JohnsonsEvilTwin
Andrew.
If you have a square, and it is ground into a rectangle, are you saying the only way to restore the profile is by adding more material?
Because it isnt.
You can sandpaper the the shape to become a square again...restoring the profile. Not magic, just elbow grease :lol:
andrew wrote: It depends how you define restoring the profile.
#-o
David Purley
marcush.
marcush.
159
even if this is a bit far off topic ,i´m pretty sure that even in F1 sometimes a bit of crude hand sanding and bodge with filler etc will be the name of the game...Also I have never seen anyone in the paddock using rulers or templates to check the accuracy of the finished product ...so maybe it looks and performs as the original thing but is it to true to the blueprint? Was it ever?
andrew
andrew
JohnsonsEvilTwin wrote:Andrew.
Because it isnt.
#-o
I am taking the same profile to not only mean the same shape but the same dimensions.
JohnsonsEvilTwin
marcush. wrote:even if this is a bit far off topic ,i´m pretty sure that even in F1 sometimes a bit of crude hand sanding and bodge with filler etc will be the name of the game...Also I have never seen anyone in the paddock using rulers or templates to check the accuracy of the finished product ...so maybe it looks and performs as the original thing but is it to true to the blueprint? Was it ever?
I think as Rob pointed out, the car was scraping its wings on the ground at Oz during Quali 1 I think. The Mechanics didnt add anything to the wing, they ground off rough areas that accumulated from the wing scraping the floor which may have had an unknown influence on Aero(front wing being important and all that).
So what they were indeed trying to do is keep the bottom of the wing as true to the original concept as before.(without adding anything)
As you can see the bottom of the wing is not a straight line running infront of the car. It is more complex than that.
David Purley
JohnsonsEvilTwin
andrew wrote:I am taking the same profile to not only mean the same shape but the same dimensions.
When I posted this??
JohnsonsEvilTwin wrote:It's good you've never heard of it, because it appears no one has actually mentioned anything about material being added.
David Purley
HampusA
hecti wrote:Congrats, you found the rule!
Now prove it, find a picture of the front wing touching the ground. I bet you cant find one.
You are joking right? Are you aware of the fact that Mechanics of RBR has sanded the wing down in some GP´s simply because of the fact that the front wing TOUCHES the ground?
"any car system, device or procedure which uses, or is suspected of using, driver movement as a means of altering the aerodynamic characteristics of the car is prohibited."
Watch 1 video of RBR onboard should light a big fire, yet it doesn´t.
Probably because FIA have no idea on what to do.
How about doubling the loads and on more points of the wing.
Reason: Removed personal comment
The truth will come out...
Well it is obvious he isnt that much joking since you couldnt provide the pic.
I would like to see a pic too of the front wing touching the ground, been watching since 2001 and have never seen it.
Reason: Removed quoted personal comment
malcolm
malcolm
Man, people like to argue on here.
By restoring profile, he means rounding off the flat-spot that would be generated by scraping. He never meant restoring the EXACT profile from out of the mold.
Geez.
PS. However, just because the wing touches the ground on occasion doesn't mean that it's bridging the gap (or at least no more so that the plank rubbing on the ground). If it dragged around on the ground for 90% of the lap, then yeah, it could be considered to be bridging a gap... but the odd scrape over a kerb or over a bump under heavy braking? Not really...
Giblet
Giblet
Please tone it down. If you disagree with someone don't attack them. Insults are not how to discuss something rationally, and if you don't want to play nice, we'll take you out of the game.
Keep in mind that just about all sensitive aero parts get sanded and cleaned by all the teams. They are pelted with marbles, pebbles, stones, and kerbs. Every team does this all the time to all their parts. Some teams sand and refinish floors a couple times a weekend. It's like keeping a board waxed.
JohnsonsEvilTwin
malcolm wrote:Man, people like to argue on here.
Geez.
:lol:
+1
David Purley
HampusA
Well obviously you can´t read or watches F1 races with your eyes closed.
Like i said, Mechanics have sanded down the bottom part of the front wing BECAUSE it TOUCHES THE GROUND.
You don´t need any pics for that, the videos clearly shows RBR´s front wing breaching the rules that is ment to be followed UNER ALL CIRCUMSTANCES.
How about you find a pic of gravity?
