Same Purpose?!?
PNSD
PNSD
Same Purpose?!?
[IMG:293:227]http://img.photobucket.com/albums/v452/ ... A106sw.jpg[/img]
[IMG:1207:360]http://img.photobucket.com/albums/v452/JBfan/wtapf.jpg[/img]
Are they for the same purpose?!
I mean isnt Hondas for creating a venturi effect, because of the higher pressure area of the sidepods?!
Thankyou.
BTW - those things on the lorry have always bugged me :P
And& If i am right about Hondas winglet/shoulder wing is it because they have larger sidepods, or does it allow them to have larger sidepods :wink:
Tp
Tp
The endplates connected to the sidepods of the Honda are there to manage the airflow around the sidepods and back towards the rear of the car.......I think the ones on the lorry serve an aerodynamic purpose but i'm unsure what, maybe again to control the airflow around it
manchild
manchild
I think that is basically serves the same purpose and that is narrowing the sideways airflow.
PNSD
PNSD
Well i understand the air pressure at that point of the sidepods in high.. therefore slower air speed...
I can understand those endplates managing the flow, but in what why.. and how...
Apex
Apex
The next person who says 'manage' or 'condition' airflow needs a solid kick! :lol:
Dont dream it, do it.
dumrick
dumrick
Some time ago, I had a talk with people in the truck business and they told me that this kind of device provides clear airstream to the exterior door handles, keeping away the black exhaust smoke and tyre projections from that area, for the drivers not to dirt their hand when climbing aboard.
This is provided by some venturi effect from the clean air captured at the front? I don't know...
Reca
Reca
93
The “thing” on the truck, let’s call it duct because basically that’s what it is, is to reduce drag and avoid separation. The flow passing parallel to the truck side, on the outer side of the duct creates near the outlet a drop in pressure, sucking the flow from the stagnation area at the sides of the radiator inlets. A similar function have the ducts you could see just in front of rider’s hands on fairings of Aprilia 250 race bikes couple of years ago (not sure if they still use them actually) and in some production bikes.
The fin on the RA106 is, presumably, mainly to split the “clean” flow passing on the inner side of the front wheel from the “dirt” flows, the one downstream the wheel and the (hot and full of carbon residues) brake cooling flow expulsed from the outer side of the rim. Nevertheless remember that basically no part of the car has only 1 function, it’s difficult, make it impossible, to describe accurately why they came up with that particular shape without knowing the details of the flow in that area.
Apex wrote: The next person who says 'manage' or 'condition' airflow needs a solid kick!
If you think that’s bad, you should hear “our virtual technical commentator” on Italian tv. For that Honda fin he would show a 3d model having a vague resemblance with the car (mainly thanks to livery) and would probably say something like : “that innovative element, fundamental factor in the ultimate design, eventual result of extensive testing in highly developed wind tunnel facilities, activates precious synergies enhancing the aerodynamic potential performance of the whole car.”
