Same can be applied to the F1 car.
The hood opening is specifically for the compressor or fan on the air craft. Yes the AoA of the air craft is the main concern with it. I was actually doing some reading on it recently.
I didn't say it will have the same exact effect, i just said it was inspired by it.
and keep your pants on romeo until you have the whole flow field. it looks like your intake would about be aligned with the local flow field from the curved forebody, but i suspect that field will change after the front wings, barge boards, etc. are added. the most efficient cooling intake will have its capture throat normal to that flow.
I don't follow you with the pants thing?
When you say curved fore body, explain what you mean.
It's not the first car i made a car or part of an F1 car, so from earlier experience i know what to expect from the wings and the wheels.
This inlet design has benefits. It wasn't tested on this specific model, it was done on model with 3 inlet configurations. And a comparison was made between the 3.
There is more to say on the inlets, but that's until the barge board and the turning vanes are made.
There are some secrets right in front of you on the tub that i wont say, but i think if a redbull designer is reading this it will stand out at them.
There are a few things i realized from the car, and it's very mathematical.
Newey uses a certain geometric philosophy. Kinda like the golden ratio, but it's not a ratio.
