Flo-Viz
strad
117
Flo-Viz
FLo-Viz is a type of paint that allows you to observe the air flow...Man I wish they would have had this stuff 30 or 40 years ago. :wink:
Short video from FP2
http://www.stradsplace.com/VIDEOS/flo-viz.wmv
Sir Stirling Moss
strad
117
Re: Flo-Viz
Well...I think the stuff is cool.
Sir Stirling Moss
Jeffsvilleusa
Re: Flo-Viz
That's pretty cool. I read in F1 racing a long time ago that teams used to attach pieces of cotton to their wings to try to determine similar information, though not sure why- does cotton have 'memory' in that it remains in the shape that it is pushed into?
That commentator is really pen-happy in that clip :D
Box! Box!
machin
162
Re: Flo-Viz
The idea is that you attach a load of short cotton/Wool strings to the surface of the car and then take photos of the car at the speeds you're interested in.. the wool will lie in the direction of flow, allowing you to see the flow pattern over the car....
Also, if the wool is blurred in the photo you can see that flow is unsteady in that area....
marcush.
marcush.
159
Re: Flo-Viz
I don´t get the hype about this.
Wasn´t this done for decades ? As an engineer you are looking for solutions to the issues you have .If it makes sense to throw a shovel of dust at you car at speed after coating it with a spill of light oil ..you might try it ...I could imagine people in the paddock invented similar methods of flow visualisation long ago..
strad
117
Re: Flo-Viz
There have been other methods, but none so clear and easy to use.
Sir Stirling Moss
flynfrog
Re: Flo-Viz
you can make your own with Kerosene and cabon black.
strad
117
Re: Flo-Viz
sure thing #-o
Sir Stirling Moss
autogyro
autogyro
53
Re: Flo-Viz
Unfortunately flow viz only gives one result a general image of the airflow through what ever speed and flow angles the car component has experienced.
It does not give a dynamic image through video coverage of all the seperate flow conditions like 'wool' tufts or smoke does.
It is however, a quick and convenient method of getting a rough idea in the field.
747heavy
Re: Flo-Viz
flynfrog wrote:you can make your own with Kerosene and cabon black.
Flynfrog is quite right,
if you fancy the flourescent look, you can use flourescent dye powder instead of carbon black, which is maybe a bit difficult to see on black/natural carbon parts.
If you are lazzy you just get this and mix it with your Kerosene aka Parrafin, and off you go.
The main reason for the use of flourescent dye is that in windtunnel testing you can use ultra violett/black light to take pictures and get a better contrast to the background.
It looks cool, but it´s not magic :) (but helpful), try it if you don´t believe it.
- Colin Chapman
Ciro Pabón
106
Re: Flo-Viz
Thanks, very interesting.
Well, I know Schlieren (that is, streaking).
Ciro
flynfrog
Re: Flo-Viz
or buy off road diesel with the dye in it that's what I did.
this book has a pretty good chapter on how to read flo viz
http://www.amazon.com/Leading-Edge-Engi ... 0837608600
