If it's well designed the spacer wont be an issue with the stiffness. The change would be academic. The rigidity wont be an issue.marcush. wrote:nah.
a spacer will seriously compromise the installation stiffness then you need new floor and to make use of the found space a reshaped sidepod would be needed as well...
But are theay really wrong with what they got? it´s not like they struggle to get into Q3 now they understand the car ..They are fighting with renault for p4 in the constructors so relative to the opposition they have made similar progress methinks.
Just think of it as an extended bell housing. It wont break any regs as the gear box is still the same.
Redbull has the longest gear box and they aren't suffering any rigidity issues.
I'd say it's a simple solution that will overcome a lot of problems.
Yes they will need a new floor and side pods, but that's the point of the spacer, to make it a whole new car.
