n smikle wrote:This is inconsistent with some arguments made on here...
But it's simply the car driving over some smoke.
THat happens to be on top of the floor as well!
You need to be calm in these situations. Anxiety can often lead to quick and wrong decisions.
This smoke comes from overheated and burning leading edge of the floor - just opposite to exhaust outlet.
It's not very high reving at the moment, but is not idling either - those cars don't go 80 kmh with idle engine on 1st gear. My guess is around 12krpm.
Visible smoke particles, if not perfect, are still the best marker we can ever see, and introduced to the flow they can make it clearly visible. That's how all wind tunnel test are done.
If the flow goes outwards - as on my first screenshot, low pressure inside this flow makes them follow flow's pathlines.
The same for moving car. All along the pitlane, and even as Heidfeld starts to accelerate on pit lane exit, there is no evidence of smoke outside of left rear tyre.
For me this means that (almost) all exhaust gases go out between rear tyres - under and over the floor.
