Why do teams use different camber with same tyres?
hardingfv32
hardingfv32
35
1) You are making these camber judgments based on photos?
2) With everyone using the same front tire, can there be much difference in front camber between cars? In general is there not an optimum camber for the front tire?
Brian
Reason: This thread was split from the Red Bull RB7 thread
Re: Red Bull RB7 Renault
hardingfv32 wrote:1) You are making these camber judgments based on photos?
Brian
Given all the cars roll differing amounts, angles and have different compensation rates. No.
marcush.
marcush.
159
Well we got two dry tyres every weekend minimum ...so from that alone there is an awful lot of compromise potentially optimising your car for use of both.
hardingfv32
hardingfv32
35
"Given all the cars roll differing amounts, angles and have different compensation rates."
Yes, but shouldn't the final camber numbers for all cars be the same at max cornering G's? Wouldn't this be where the tire produces max cornering performance? Shouldn't everything be done to give the tire exactly what it wants?
Tire compounds: how do different compounds effect the camber requirements? Isn't the construction the same?
For discussion purposes I am assuming that we are attempting to get max performance from front and rear tires. I appreciate that some reduction in performance at one end could be required for balance requirements.
Brian
raymondu999
AFAIK camber is to maximise contact patch when the car is in roll. Theoretically, when you make a car stiffer, it rolls less, and you should put less camber. When you have it softer, and let it roll more, then more camber is ideal.
失败者找理由,成功者找方法
hardingfv32
hardingfv32
35
Why wouldn't the camber curve be designed to match the amount of roll you have?
I guess we should specify that we a talking about camber at max cornering force, not the static setting. Should the camber setting for all cars be about the same at the max cornering performance point?
Brian
raymondu999
It would; but then each different team's cars would have different suspension settings which would dictate different amounts of roll.
失败者找理由,成功者找方法
HampusA
All cars are different, one number might not be the same for the other teams.
The truth will come out...
Might not even be the same between cars in the same team...
hardingfv32
hardingfv32
35
So... you are say that the tires have a variable sweet spot? That you can get equal performance from the tire with different maximum cornering load (dynamic?) camber readings?
Brian
raymondu999
Sounds like a question for JT; and for a new thread.
失败者找理由,成功者找方法
kalinka
kalinka
hardingfv32 wrote:So... you are say that the tires have a variable sweet spot? That you can get equal performance from the tire with different maximum cornering load (dynamic?) camber readings?
Brian
Why would it be so impossible ? Cars do have other variable sweet spots, that we know for sure, like balance,wing AoA,suspension settings...etc. It's too dependable of the driving style. We could see all year that teammates having quite different setups, could be alongside each other in qualy and race too. (IMHO)
hardingfv32
hardingfv32
35
The driving style in the case of a spec tire needs to be configured to optimize the tires performance. Some drivers will need more setup compromises than others to optimizes tire performance, but the fewest compromises equals the highest level of optimization.
Brian
Jersey Tom
Jersey Tom
hardingfv32 wrote:"Yes, but shouldn't the final camber numbers for all cars be the same at max cornering G's? Wouldn't this be where the tire produces max cornering performance? Shouldn't everything be done to give the tire exactly what it wants?
No, not really that simple.
hardingfv32
hardingfv32
35
Hoping to learn something.... Why not?
I am assuming that we are trying to get max performance from front & rear tires. Also, we do not have to degrade the performance of either end to solve some kind handling problem or driver preference.
Brian
