The multilink you can take advantage of the movement of the body of the car. You can also make the wheel move in all sorts of ways as it rise/falls. Multilink is the best suspension in my opinion.gorain wrote:is it correct to replace the double wishbone suspension with multilink suspension in a racing for environment like UK
you can do all of that with a Double A arm as well. As Tom said they are just different. You certainly wont gain anything by cutting one suspension off a car and trying to adapt another suspension to it.n smikle wrote:The multilink you can take advantage of the movement of the body of the car. You can also make the wheel move in all sorts of ways as it rise/falls. Multilink is the best suspension in my opinion.gorain wrote:is it correct to replace the double wishbone suspension with multilink suspension in a racing for environment like UK
BMW's have a hybrid multilink suspenison on the front axle now. Check out the front suspension parts of the 7 series below.
Three ball joints at the bottom of the upright... (two linkages + tie rod)
and a more conventional A-arm at the top.
http://realoem.com/bmw/partgrp.do?model ... g=31&fg=05
ride over bumps has little to do with the type of suspension. You could do the same thing you are stating by having your a arm pivots on different axis.n smikle wrote:Just a point of observation.
The double wishbone there is one constant distance from the outer ball joint to the axis of rotation of the lower A arm.
In the multilink this distance varies as the wheel moves because each linkage in the multi-link can move in more than one plane.
This is because, from the plan view the two separate lower linkages form a non planar quadrilateral (or 3 dimensional 4 link) with their mounting points and the upright.
It is like having a double wishbone with the legs of the A-arm variable length.
This is a significant difference to me. I think the car can ride better over bumps. It could really be useful in F1.
Yes, I expect it to be hell to tune.
In that case, all suspension are, in some way.Jersey Tom wrote:Again.. a double a-arm is just a specific implementation of a multi-link suspension.
Not quite true. I believe multi-link only refers to independent suspensions, and there are quite a few types of suspensions that do not qualify as such, for example beam axles.Caito wrote:In that case, all suspension are, in some way.Jersey Tom wrote:Again.. a double a-arm is just a specific implementation of a multi-link suspension.
