After the disaster of my Red Bull RB6 - there were too much mistakes in that car - i decided to built it's successor, the RB7. When I built the RB6, i learned a lot about modern Formula 1 cars and that new knowledge i can use in the manufacturing process of this car.
Here are the first pictures of the monocoque. It's very robust. I took 4 layers of 0,5mm cardboard, each with a 90° angle to each other and a 0,3mm black cardboard for the internal coating. And with the external blue layer, which will come in a few days, the thickness of my Monocoque structue will be around 2,7mm (the FIA reglement dictate a minimum thickness of 25mm - in my scale of 1 to 10th are that 2,5mm).
![Image](http://img571.imageshack.us/img571/1743/k800img4857.jpg)
![Image](http://img231.imageshack.us/img231/1965/k800img4860.jpg)
If somebody is very interessted, you could also look at this german forum:
http://www.modellboard.net/index.php?to ... 524056#new
Cheers,
Paul
