raymondu999 wrote:myurr wrote:And bringing 5 or 6 special sets of tyres for qualifying isn't wasteful (one or more for practice sessions, four for the four runs a top team will do in qualifying)? Or do you only bring them for a single shot at Q3? All seems a little unworkable to me.
Q3-only, apparently
Sounds pretty pointless then. The balance of the car on those tyres will be different, so it's going to most likely be that one team will luck in to a car that is naturally balanced on them with their normal setup whilst others will be less lucky. That's going to lead to one team or another having a qualifying advantage, not through skill but through luck.
And that will be doubly so if they don't also bring tyres for them to practice on. And if the top teams get to practice on them, then they'll all need to practice on them otherwise how do you decide which teams will and will not get the quali tyres?
This is going to be a complicated, unholy mess. They either need to go for it whole hog and bring another 5 - 6 tyres per team so that they can all run them in free practice and qualifying; or they should just bring one more set of option tyres for each team and accept that as being the simplest solution to the teams doing only one run in Q3.
