Team: Tony Fernandes (TP), Riad Asmat (CEO), Mike Gascoyne (CTO), Keith Saunt (COO), Marianne Hinson (HA), Lewis Butler (CD), Elliot Dason-Barber (Head of R&D and Vehicle Dynamics) Drivers: Heikki Kovalainen (20), Jarno Trulli (21)
they will be team caterham air asia as tony has dropped the lotus name for a 20% share of the govt owned airline and has been put in charge of running it
T128-01 History:
Kovalainen: Valencia Test, Jerez Test, Barcelona Test #1, Barcelona #2 Test, AUS, MAL, CHI
Trulli: Valencia Test, Jerez Test, Barcelona Test #1, Barcelona #2 Test, CAN, EUR, GBR, HUN, BEL
Teixeira: Valencia Test Day 4, Barcelona Test #1
Valsecchi: Barcelona #2 Test, MAL FP1
Razia: Barcelona #2 Test
Chandhok: EUR FP1, GER
T128-02 History:
None (Posibly car they have used for crash testing and also the car they use for straightline aero tests now, also car for their 7 post rig usage)
T128-03 History:
Kovalainen: Barcelona #2 Test
Trulli: AUS, MAL, CHI, TUR, ESP, MON, ITA
Razia: CHI FP1
Chandhok: AUS FP1, ITA FP1
T128-04 History:
Kovalainen: TUR, ESP, MON, CAN, EUR, GBR, GER, HUN, BEL, ITA
Chandhok: TUR FP1, GBR FP1, BEL FP1
Why power steering for F1? I think the "because they have downforce" answer is too simple and incomplete.
During transients (turning into a corner), steering wheel weight is heavy because the caster causes the steering motion to extend and compress the dampers. You are literally pumping the dampers via the steering wheel.
During steady-state cornering (holding constant steering in the middle of a corner), steering wheel weight is heavy because kingpin angle and scrub radius raise the front end of the car up from its non-steered height. You are literally holding the car weight and downforce up via the steering wheel.
The transient situation does not depend on downforce, but the steady-state situation does. It would be possible to make a car with no kingpin/scrub that had constant steering weight regardless of downforce.
I don't know which effect is more important in a typical modern F1 car. Perhaps the complex interaction of transient vs steady-state steering weight was the reason that Lotus couldn't just dial the power-assist boost up or down to satisfy Jarno Trulli.
Slightly off topic, but what car is this? It's a pre-2009 car outfitted in Team Lotus colours, which I can't really understand as they didn't buy anyone out for their F1 entry.
PaulB wrote:That should be an early 2000's Arrows.
If that is the case I believe Paul Stoddard acquired a number of these when Arrows folded and had them as display cars dotted around Australian Airports, a few of which I believe were lifted from display and used as Super Aguris in their first year.
