Can't find anything in the link you mentioned in your previous post mentioning it needs a primary power supply...the only thing it says is:
The Lundell alternator (the technical name for a clawfoot-rotor alternator) requires two watts of energy(power? my terminology is slipping) to spin it for every one watt that it produces.
The energy that is mentioned here is the rotational energy that is brought to the alternator from the belt connecting to the engine! It like hp it's a way of representing energy! 1 hp = 745.699872 watt!
So basicly the alternator removes from the engine: 2 watt (= 0.00268204418 hp) for every watt "transformed" into electrical energy!
Concerning a dynamo and a alternator:
dynamo:
- A machine for converting mechanical energy to electrical energy. Common name used for direct current generators.
- A device that generates electric power from the engine's activity.
- A device that produces Direct Current from a rotating shaft.
- The process in which the motion of electrical charges generated a magnetic field.
- generator consisting of a coil (the armature) that rotates between the poles of an electromagnet (the field magnet) causing a current to flow in the armature
alternator:
- A part of the electrical system which converts mechanical energy from a drive belt into electrical energy to operate the ignition, electrical accessories and to charge the battery.
- A type of generator used in automobiles to produce electric current
- A device that produces Alternating Current from the rotation of a shaft
- An electrical generator that mechanical energy into elec- trical energy for powering circuits in a vehicle. With the engine running, the alternator recharges the battery
- A device powered by a vehicle's engine that creates electrical energy to charge batteries and power on-board devices
Well...like you see both of them are quite similar! Both create alternate current...while the alternator has diodes that make the circuit as an AC...the dynamo in same cases doesn't! And I've always been told that a alternator is a specific kind of dynamo! In both cases you can charge a battery.
