Red Bull ride height and flexi-wing solved?
Reading post on this forum and others, there seems to be a general consensus that both these things are happening, but how they have achieved it has yet to be convincingly and thoroughly explained. Why can't we see anything conclusive on television? I believe it’s because of the clever way they are hiding it. They are using an asymmetrical fractal geometry tuned mass damper. Specifically, one tuned to the frequency of the formula 1 television feed of 25 frames per second. The shape of each damper is such that it will spin at a constant frequency regardless of the forces applied once a minimum amount of energy applied. One damper is located at the hub of each wheel. Because it’s always at the same place when each frame is taken, the asymmetry is unnoticeable. In this video clip of early testing it clearly shows the device at work and not in tune with the video feed. I suspect they hadn't perfected the shape yet.
http://www.youtube.com/watch?v=Xx04Wp0hy_Q
I also believe this is why Mclaren was using the strange front wing testing device preseason. It allowed them to tune their front wing without showing the strange oscillations that would be visible if it were slightly out of tune with the television feed. How then do they use this to adjust the ride height and front wing while maintaining a rigid chassis?
The effect of the asymmetrical masses spinning cause the car to pulse up and down. I'm sure red bull have a system similar to Mercedes as described here on scarbsf1 that instead allows the car to ratchet down with each cycle, but limit the amount it can go back up by using a very slow bleed valve.
http://scarbsf1.wordpress.com/2011/10/1 ... uspension/
As the RB7 (and RB6 as it used the same system) reaches minimum ride height, the rigidity of the chassis is achieved in the same way one's elbow locks out if one extends their arm. Because this system of lowering the car relies on these tuned dampers spinning freely in the wheel hub, they would lose effectiveness as soon as the brakes are depressed. Ferrari uses a similar system, and this would explain why his wing instantly stopped vibrating as soon as he hit the brakes. Also, he had a tire that had a slow puncture and I think this caused the excessive vibration in the first place as the mass dampers went out of phase and sufficiently damaged his suspension causing the failure later. Vettel and Webber drive suspiciously slow back to pit after each session, to allow the car to return to the original ride height so no stationary pictures of the car are taken showing a different rake angle. The drivers probably tail brake all the way back to the pits to insure full ride height is achieved.
The pivot point of the chassis is probably right in the center of the car allowing the legality plank to flex as a "see saw splitter" as explained by, u guessed it ScarbsF1 right here.
http://scarbsf1.wordpress.com/2011/10/1 ... -solution/
The flexible front wing is achieved by tensioning the controversial wires seen hanging from Red Bulls front wings several times. When Massa's wing shattered in India and the end plate went flying, I’m quite sure one can see the wires there, too, as it also uses this same system. When ride height is at its maximum, these wires support the front wing and allow it pass the legality test. When the ride height is reduced while the car is moving, this releases the tension on the wires and allows the wing to flex down as observed.
http://www.youtube.com/watch?v=GboweGhYixc
The genius of this system is that they can use it in plain view of all the cameras and it can't be seen because it is in sync. I think this is why the other teams have taken so long to figure out what is going on. I suspect that many of the key features on current f1 car designs will be reinterpreted if I am correct, specifically the high nose cone, angle of rake, shape of the nose cone including reinforcing bulges running along the edge, pull rod suspension, and front wing aerodynamics. The efficiency of the diffuser must be increased significantly by changing the shape of the floor. I have much more to say on this subject, but I wanted to get this out there to make sure it will stand up to criticism and I can't wait to see the reaction if this does indeed prove to be true. Thanks in advances for your time.
Joel Dickerson
(First online post, go easy)
