n smikle wrote:I didn't realy read all of that, because I know what I am talking about 100%
It was mostly equation manipulation (ie not long) and was rather simple to follow.
In any case I wouldn't dream of wasting my time, answering questions to someone that already knows all the answers.
EDIT: Because I can't help my self. I'm not explaining, I'll just give the equations. As they can't be argued with.
n smikle wrote:
1. Where does the torque come from in the piston engine? (trace it right back to the intake and fuel)
Leading question, as I know what you want me to say.
And it’s a subtle difference because energy and forces are different concepts. Which is why you can consider them as simultaneous products or inputs, not consequences of each other.
Just as we consider power output and work output as simultaneous and non consequential. (as P = Tw).
We consider power in and heat in as simultaneous and non consequential. (deltaE/T = deltaQ)
So we can still quite rightly talk about:
Power in = work ouput.
Heat input = power output.
Power input = Power output
Heat input = work output.
All the above 4 are equally correct. And each has their specific use.
n smikle wrote:
2. How efficient is the typical IC Petrol engine?)
η = 1 – (1/Rc^(γ-1))
Where gamma is 1.4 for air cycles. And typically 1.3 for stoichiometric AFR.
n smikle wrote:
3. Where does the.... REST OF the UNUSED POWER.... go to??)
δE = δQ – δW
1st law - standard convention of signs.
As torque clearly relates to mechanical work, any arugemnt that Q is not Tw is obvious and meaningingless.
For example if we only ever used power for designing engines, how could we design the components? As power tells you nothing about physical loads due to combustion. You’d need to infer it by trying to work out how much fuel was burnt and estimate gas quantities and cylinder pressures. In these cases, measuring forces and torques is far more important than knowing your power output.
Just as calculating acceleration from torques only is more difficult that power only.
Right tool for the right job.
