Red Bull RB7 Renault
astracrazy
astracrazy
31
Re: Red Bull RB7 Renault
Lorenzo_Bandini
Lorenzo_Bandini
I didn't know if it's true, but i like this article :
http://translate.googleusercontent.com/ ... hGVvK9ubvQ
f1motta
f1motta
64
More RB7 photos from YDT in Abu Dhabi http://www.f1talks.pl/2011/11/15/red-bu ... -kierowcow
chepoi
chepoi
Lorenzo_Bandini wrote:I didn't know if it's true, but i like this article :
amazing article!!!! thank you.
aleks_ader
90
astracrazy wrote:Image
It loks Red BUll choose more practicaly, quick and more sipmle solution than Mclaren (http://www.sutton-images.com/previews/dcd1108ma27.jpg) for front wing flex test...
Richard
Richard
RB had that test rig in Feb 2010, McLaren first used their version in Feb 2011.
Not sure we could say one is different to the other, they look identical to me other than different shaped covers.
aleks_ader
90
richard_leeds wrote:RB had that test rig in Feb 2010, McLaren first used their version in Feb 2011.
Yes exactly i thin the same! But i thik that Red BUll dont need to produce the another wing like Meclaren. Beacuse the could glued the suport "beam"...
Isak
Isak
RB are running 5 ride height monitors on the front wing aswell;
raymondu999
Interesting. If those fat vanes are really ride height sensors (I can get how the middle one is, but how do the ones on the endplate see "through" the endplate?) that would indicate they expect that relative to the middle plane they expect the height of the endplates to change - i.e. flex along its length
失败者找理由,成功者找方法
Richard
Richard
How about a hole in the end plate base so they can see the ground?
They would measure flex in pitch and roll, ie up/down and twist when viewed sideways.
I wonder how they separate out the effect of those cables that seem to measure the force? Surely the cable will stop the wing deflecting?
raymondu999
richard_leeds wrote:I wonder how they separate out the effect of those cables that seem to measure the force? Surely the cable will stop the wing deflecting?
Maybe they're so compliant so that it only measures the force? Though they would undoubtedly exert a counter-force
失败者找理由,成功者找方法
beelsebob
beelsebob
85
richard_leeds wrote:How about a hole in the end plate base so they can see the ground?
Well yes, but the amount of force on it will tell them exactly how much it will deflect, with multiple tests allowing multiple amounts of deflection you could build up a pretty solid picture of how much it bends and how.
Intego
Haven't you had these dynamometers at school? Simple as that ...
Meanwhile ist's digital and connected to computers ...
mariano.torre.gomez
mariano.torre.gomez
What is the idea behind this test rig?
thanks
astracrazy
astracrazy
31
thanks
I seem to remember testing like this for the 2009 prototypes towards the end of 2008 (BMW comes to mind) and has been used by some teams ever since.
I think it measures the amount of movement/flexing of the wing. Obviously when it pulls down towards the ground it pulls the chords which will get a reading.
