I think I appreciate the how the the generation of down-force by the floor has been generally portrayed. The flow velocity is increase and low pressure generated. I am disregarding the rear diffuser assembly for this discuss. Just discussing the operation of the floor in isolation from the rear diffuser IF possible.
With the current 2-3 degree floor rake of most cars, the floor looks like a diffuser with the volume constantly expanding from the leading edge to the rear diffuser assembly. There is almost no funnel at the front to force flow under the splitter. Looks like the splitter directs most flow above the floor entrance. Just the chamfer on the plank and maybe 15 mm ground clearance to let air under the floor. No apparent nozzle.
So how does the underside of the floor function as an aero application?
Brian
