1) If we assume that all the additional winglets and curved slots on the latest front wings are for vortex formation, I would say F1 is still test the quantity limit of vortices.
2) Wanting to stay focused on the leading edge of the floor:
A) Is there any reason to expect that all the new wing vortices are making it to the center and down to the leading edge of the floor? I would think you need to insure that any vortex approaching the floor needs to make its way under and not on top of the splitter. Is this a correct thought?
B) Is there anything about the leading edge of the floor that would cause vortex generation under the floor? That is not normally a property of a straight wing leading edge perpendicular to the flow axis is it?
Shelly, thanks for having me revisit the delta wing properties.
Brian
